Round Vision / View - Cameras in mirrors
I recently got hold of the ACM and am still wondering if I really need it. I bought it simply to keep the Group Buy going but I've also been doing some reading up.
Instead of the front and rear cameras I actually wanted to install cameras in the mirrors to see how close I was to kerbs etc. It was one of those Eureka ideas which when you do some looking around you realise has already been done. I found various Japanese cars have this feature but then I found the attached picture in the ETK. Has anyone heard of it, seen it?
What about part numbers for it. If you look at the ETK screen I think its wrong because although the part listed is part 2 (rear camera) the part description says mirror cameras. However the mirror camera parts don't show up for the e60 but neither does the front camera but various people have installed it. I remember seeing a promo video for the self parking BMW and that seemed to suggest side cameras at the time.
Can someone also remind me what the part numbers for the front prism and the rear camera are please.
![Round Vision / View - Cameras in mirrors-roundview.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/41058d1482365589t-round-vision-view-cameras-mirrors-roundview.jpg)
My Ride: G30 M550i
Model Year: 2018
That's the first I've seen any mention of side cameras -- neat find Bruce!
I think the part number 2 that is listed in your diagram is the one for the side mirror cameras. Take a look at the following realoem diagrams:
Round Vision:
http://www.realoem.com/bmw/showparts.do?mo...;fg=95&hl=2
Front Camera:
http://www.realoem.com/bmw/showparts.do?mo...hg=66&fg=95
Reversing Camera:
Round Vision:
Front Camera:
Reversing Camera:
I saw that on realoem, in fact that diagram is even more confusing. It doesn't even make any mention of the side cameras in the diagram. The part is number 2, which in the diagram points to the front prism camera. But the part number and the description are the same as the ones I posted.
The front and rear camera links seem to be the entire retrofit kits and not only the camera themselves.
You're right, Bruce, that front and rear links are entire retrofit. I believe BMW does not sell rear or front cam individually. Here is the installation instruction for front camera and as you can see they sell it as a package.
BMW_Rear_Cam.pdf
BMW_Rear_Cam.pdf
Fred, Didn't some people here install the BMW front and rear camera with the ACM. How did they get hold of the parts then.
OK I found it.
Looking at http://bmwfans.info/part-66210301009/ you can see the front camera is 84 21 0 304 187
Looking at http://bmwfans.info/part-66210412010/ you can see the rear camera is 66 21 0 407 000
But when you look at the Round Vision http://bmwfans.info/original/E60/Lim/550i-...66/ill-66_0107/ it starts getting interesting. Because according to this site the Round Vision is actually a complete kit of the front and rear cameras along with the ACM too! Absolutely no mention of a side camera in the set.
So I put my part number in the URL directly http://bmwfans.info/part-66210417353/ and voila a part appears. Its again a Retrofit kit but with mirror cameras. Its for X3 E83 LCI and the actual camera part number is 66 53 3 418 694 but only for the passenger door mirror. But its the same part for the RHD and LHD drive cars so I think its the same camera used on both sides.
And then there is http://bmwfans.info/original/E70/SAV/X5%20...66/ill-66_0141/ which is again for the passenger side only for the E70 in Japan.
are these camaras really not used to check for blind spots when you change lanes?
The reason why i am asking is because we are currently putting a bit of resources in working with the chip manufactures for the car industry in developming cmos sensors that will eventually replace the outside mirrors and instead we will have small lcds in the car.
They are supposed to be for blind spots.
Update : I tried calling BMW and checking prices for the cameras themselves on their own and no luck. BMW wont sell the parts seperately, they must be ordered as the entire kit.
My Ride: Black BMW 525i Touring
Hi Bruce,
I have installed the ACM with a rear camera. When you do that the LDV converter is no longer required. As far as I know you can only add the front and the rear camera to the ACM unit. I have not seen the option to add the mirror camera's before.
Rear view works like a charm.
Midget
Midget
Midget, Did you have to buy the entire front and rear retrofit kits but only use the cameras from them with the ACM? It seems better to buy the entire Round View kit 66 21 0 420 510 if you want ACM, front and rear cameras.
