Rims with offset 18 or 41 ??
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I am on the market for new set of winter wheels. A shop is offering ones that fit 5 series BMW ones but there are 2 different offset (same model/brand).
Which one I should go: 18 or 41? They said the 5 series is up to 25 so I am told to get 18 offset? but my summer rims are 30 offset... I am confused.
My Ride: .
Model Year: .
My Ride: 2008 BMW 535XI white
for RWD model, I
offset should be around 20mm
for AWD model, XI
offset should be around 40
i am looking for 19x8.5, so offset should be 35-40mm
also depends on the width you are getting
for AWD model, XI
Originally Posted by mrfva' post='1022998' date='Oct 2 2009, 09:07 AM
41 offset sounds too high, more like an Xi offset. I say go with et18. What size are the wheels?
5/120 41 Silver
5/120 18 Silver
the tires will be all 245/45R17 XL NoK Hakk R 99R
CORE RACING B3-5 Series
http://www.kaltire.com/images/wheel_...ries_CR675.jpg
so 18 sounds right.... Do they need spacers?
Thank you!
Originally Posted by C's Bimmer' post='1023016' date='Oct 2 2009, 09:25 AM
Being a former XI owner, the 41 offset they have is for the xi model only or a 3 series. You want the lower of the two. Since these are winter wheels for your car, I would assume same width at all 4 corners? If so, 18 should be fine. If you have a wider rear, you'll want that to be around 30ish...
thank you C! so I will stick 18 then.
http://www.1010tires.com/WheelOffsetCalculator.asp
Originally Posted by miguex' post='1023040' date='Oct 2 2009, 08:52 AM
17x7.5
5/120 41 Silver
5/120 18 Silver
Thank you!
5/120 41 Silver
5/120 18 Silver
Thank you!
Those look like my OEM 125's
Originally Posted by C's Bimmer' post='1023406' date='Oct 2 2009, 05:02 PM
bookmarked! thank you!
