Retrofofiting Headlight Washers
My Ride: 05 530D Sport E61
Im fed up with not being able to see at night because of the amount of bugs that apear at dusk and cover the headlight in their corpses!
The solution was the retrofit kit 61 60 0 301 027 what a hassell!!, not exactly what you would call plug and play!. Ive got all the mechanicals done, but I am struggling with the electrical connectors as the instruction are generic to both left and right hand drive.
Ive found , X11004 Pin 1 & X13782
X13783 apears to be just an earth block so should be easy enough to find one
X13252 Pin 1 describes itself as "base module" this I think ive found located just below the main fuse bank, but how can I confirm it?
I assume these X numbers are not part numbers but is their any way to crossrefer them to OE part numbers and confirm my assumptions
Help!!!!
Help!!!!
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
