Retrofit heated steering wheel?
Hi,
I've got a sports steering wheel with SAT. But it's not heated. When I ordered by car, the option wasn't on the list - by the time it was already in production, the option had appeared (for about ?110) but it was too late to add it to my car I didn't mind at first, but now we are in winter, and having experienced my wife's X5 with heated seat, I really really want this option.
So, is it possible? Would the car need reprogramming? I haven't got a clue where to start ... other than saying "my hands are cold, please help!"
Originally Posted by Russ1974' post='511438' date='Dec 28 2007, 02:46 PM
Hi,
First, whats up with the creature with the horns? I don't want to see that thing in my sleep...
I have the heated wheel and love it. I live in the Northeast US. I would guess your build date would determine if you can add the heated wheel and activate it. If the required wiring isn't built in I doubt you can easily add it if at all.
I actually believe that the heated steering wheel should be very easy to retrofit especially since its offered as an option. When I took it I had to take the heated front seats too but boy do I love that option. I thank my wife for insisting that I take that. The heating element in built into the wheel and has no idrive controls so all it requires is a switch to control the 12v supply to the wheel and you should be done.
I'm on holiday at the moment so dont have access to the WDS to verify my thoughts but I'm sure someone will chime in.
Originally Posted by Russ1974' post='511438' date='Dec 28 2007, 08:46 PM
Hi,
Let us know, Russ : I forgot to get it at the time of the order and on mountain @ -15? C the steering is *extremely* cold, although the seats are heated .
Model Year: 2005
Engine: 545i
I have it and it's a cosy little option.
I'm in the process of retrofitting the smg paddle kit from Fred - which uses the heater pins through the coil spring - gonna bring parallel cables through the coil spring so I don't lose that heater option, it's that great during winter !
The coil spring is the same part no. for heated/non heated so no problems there Russ. You will have to change the switch element on the steering wheel and bring power from a point located close to the lights switch on the left dashboard console.
Attachment 42326
Attachment 42326
We will not need to change the steering ?!?!?!
I thought so .
Wonderful!!
Model Year: 2005
Engine: 545i
I thought so .
Wonderful!!
I thought so .
Wonderful!!
Originally Posted by andy545' post='511690' date='Dec 29 2007, 08:26 PM
Of course you will Alex - you need the heated element in the rim.
It seemed strange indeed .
I expect a new steering wheel will be very expensive ... it's one of those things that you can order as an "I want this instead of this" option and it's cheap from the factory. But to get a new sport steering wheel with paddles, airbag, with the right buttons to match my spec, I think it's going to be stupidly expensive. If anybody with enough parts knowledge could perhaps take a guess at what parts would be needed along with prices, it would be appreciated. Once I know it's going to be ?2,000 I can get the nagging thought out of my head and learn to live with what I've got !
We should get it on eBay at the first chance . Maybe the new M5 heated one, but on eBay.de every ad of M5 steering wheel arrives to EUR 6-700 .
