retrofit headlights to lci from pre-lci need wiring diagram???
Old 04-26-2015, 08:09 AM
ricki_'s Avatar
My Ride: BMW e60
Default retrofit headlights to lci from pre-lci need wiring diagram???
hey i want to assemble the new facelift headlights on my BMW E60 my car is pre-LCI 2005. I was wondering if anyone fitted these without coding? by the way this is what i want to upgrade from
the old pre- lci headlights
retrofit headlights to lci from pre-lci need wiring diagram???-e60_07_10_06.jpg
to the new Lci headlights
[ATTACH]147782[/ATTACH
not my pics
Attached Thumbnails retrofit headlights to lci from pre-lci need wiring diagram???-img_4014.jpg
Old 04-28-2015, 04:42 PM
justalilbit's Avatar
My Ride: bmw
Hey ricki, check this post out: https://5series.net/forums/e60-parts...13/#post561074
It includes the .pdf of BMW's installation/wiring instructions. Note that there may be mismatched pins, the post explains it specifically. Also check this thread out: https://5series.net/forums/diy-do-yo...nstall-114185/
You can never do too much reading when you're attempting to take on a project of this magnitude. Also, without coding your angel eyes won't stay lit, you'll have some other issues too. No way around it, you need to code the LCM II after installing it.
AFAIK you could skip buying the LCM II, coding, wiring, tails etc and simply plug and play the LCI headlights, but they wouldn't work properly. (The angel eyes only stay lit for a few seconds, etc)
Old 04-30-2015, 05:18 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
or buy some aftermarket lci like lights off ebay. lol
Old 05-02-2015, 11:47 AM
sanjsanj's Avatar
My Ride: E60 530d
Attachment 147781
not my pics
If you had pre lci BI xenons (i.e. the xenons worked when you used full beam) then yes, you could fit them without coding, you would need to fit 10w led angel eyes otherwise the angel eyes wouldn't work.
If you didn't have xenon full beams with your current set up then you will not get that function in your lci headlight, if that picture is an EXACT, IDENTICAL picture of the lci headlights you have. If you have one with cornering lights, DO NOT use full beams at all, unless you code the car.
Old 05-02-2015, 03:28 PM
bmwrider2010's Avatar
My Ride: BMW 550i
Attachment 147781
not my pics
your pre lci is adaptive. the one you pointing lci is non adaptive. you will get cornering lights error in idrive. you have to go for lci adaptive, but then you have to get lm2 otherwise your cornering will work as full beam.
Old 05-05-2015, 12:24 PM
ricki_'s Avatar
My Ride: BMW e60
thanks guys for all your repaly and the good information about the retrofit i tried to fit the headlights but realized the the connector are diffrent in pre-lci so I orderd some cables and conectors.
going to wiring up something like this now that i found the diagram here in the forum.
Old 05-05-2015, 12:29 PM
ricki_'s Avatar
My Ride: BMW e60
I've seen them before there are some other models also but orginala LCI looks hotter
Old 05-05-2015, 11:59 PM
turboawd's Avatar
i'd be curious how these look in real life. they have design cues from the newer 5 series.
Old 05-06-2015, 11:03 AM
ricki_'s Avatar
My Ride: BMW e60
It would be nice to see this in real life how the headlights look.
Do you now any member here who installed this on his car? Or are there pictures so we can take a look how they fit on the car
Old 05-07-2015, 11:33 PM
seven11's Avatar
My Ride: 535
those aftermarket headlights look terrible
Quick Reply: retrofit headlights to lci from pre-lci need wiring diagram???
