Removing wheel spacers after 3 years
Old 05-03-2009, 06:35 AM
monacobmw's Avatar
I have given up trying to find the old email strings.
I need to turn in my leased car, and today, I am changing back my old wheels.
My spacers will likely be rusted to the wheel hub.
How do I remove them????
What is the prevailing thought??
I know all about using anti seize to put them on, but we are far past that point...
I am sure that spraying some stuff in the gaps will help, but I recall that some here used other methods.
Old 05-03-2009, 07:12 AM
mhs525's Avatar
The only way I know to get stuck spacers off is with a thin blade screw driver and a hammer after soaking them many times with penetrating oil and letting them sit over night. The spacers are softer than the hubs so they get gouged up pretty bad but the hub should be OK. It also helps to heat the spacers with a propane torch to get them to expand off the hub. You can heat the spacer then put some ice on the center of the hub. Place a screw driver or punch in one of the spacer holes and drive the spacer sideways (rotate on the hub) to break the rust seal before you try and lever it off with the small blade screw driver.
After having gone through this once I grease the hub and spacer, a lot, twice a year when swapping back and forth between summer and winter tires.
Good luck... this could suck... a lot
Let us know how it goes
Old 05-03-2009, 10:44 AM
DrLev99's Avatar
If you don't care if they are destroyed, you can use a hammer with forked end. Wedge the forked end on the inner aspect of the opening and start pulling like you are pulling out a nail. You might have to really force it off.
Old 05-03-2009, 10:47 AM
CWS530's Avatar
This may be one of the single best phrases a person can know. It applies to so many siuations!
Old 05-03-2009, 11:42 AM
monacobmw's Avatar
The solution is:
The blow torch.
I sprayed liquid wrench in the space between the spacer and the hub (there was no space). I hit the area with a rubber mallet.
I heated up the aluminum for about 5 minutes. I saw the rust bubbling from the inside out.
Then, I put a putty knife (sharpened on one side) in the space between the spacer and hub and used the rubber mallet to create some extra space.
The space opened up pretty easily.
Then, I put a screwdriver into the small open space to wedge some extra space.
Not very hard. Just took some patience, and the blow torch was the secret.
It sucked only a little, not a lot.
Old 05-03-2009, 12:58 PM
DrLev99's Avatar
Well, if I had known you had a blow torch just lying around......
Old 05-03-2009, 01:02 PM
Gene's Avatar
does a can of hair spray and a lighter count
Old 05-03-2009, 05:57 PM
acuteperformance's Avatar
My Ride: 14 550i
Probably could've used a plasma cutter too.
Originally Posted by monacobmw' post='866930' date='May 3 2009, 12:42 PM
The solution is:
The blow torch.
Old 05-03-2009, 06:14 PM
monacobmw's Avatar
Just $15 at the hardware store for the torch.
If you are inclined enough to be doing this yourself, surely you can operate a blow torch.
It was the secret, and I would have been working on the spacer for hours without it.
Old 05-03-2009, 06:19 PM
My Ride: 14 550i
Oh you mean one of those pencil torches w/ butane?
Quick Reply: Removing wheel spacers after 3 years
