Recommendations on Pipes
I'm sure there's a few threads on this already, but searches come up with a 100 different topics that aren't what I'm looking for. So feel free to direct me to another thread.
I'm looking to do a m-tech kit on my 530 but have some reservations about changing out the exhaust. Going to a quad setup looks badass, but I've read that I will actually loose power (I'm guessing from a decrease in back pressure). While I really don't want to loose any power, my main concern is noise. I've had several cars with aftermarket pipes, and while they are all sport/race cans, I can't deal with a constant, loud buzzing. This is my daily driver and long-distance cruising car, I don't want a headache.
My other option is to just keep a single-sided setup and change out the tips to something beefier, but let's face it... it's not as cool looking.
So any advise on a set of quad pipes that won't kill my power and are not much louder (if at all louder) than stock?
Thanks- Marc
Thanks- Marc
I have the duel pips which I am loving it.
GH-NA25,GH-NA30
ABA-NE25,ABA-NE30
http://www.arqray.jp/pages/twinpipe/index.html
My Ride: Current: '08 535i
Recent BMW:
'95 M3 (swapped)
Engine-
Swapped '95 S50 with '99 S52 3.2L bored/stroked to 3.3L, kept OBD1
JE Pistons (9.0:1 compression ratio)
Pauter connecting rods
Schrick Camshafts
Vortech V2 w/ custom bypass valve
RMS Aftercooler
Head modifications Ported and Polished, large valve springs and retainers,
Valves Yes, but don't know name
Valve springs Yes, but don't know name
Retainers Yes, but don't know name
Electromotive TEC III stand alone engine management, tuned by Vic Sias of Sias Tuning
S50 Intake manifold
Dinan Throttle Body
42lb Fuel injectors
Custom RMS air intake
RMS Header
Custom header-back exhaust
Quad exit rolled tips, polished exhaust
High flow catalytic converter
NGK Spark plugs
B&M short shift kit
Centerforce Dual Friction clutch
Odyssey PC 680 Lightweight Battery
Exterior-
House of Kolor Moondust Silver
Custom 1.5" flares molded into body
Trim painted and molded into fender flares
Dresmann body kit from Germany (front bumper, sideskirts, rear bumper)
Kerscher 3 piece CF spoiler - imported from Germany
CF side mirrors
DTM Authaus CF vented hood
Lighting-
Gourmet Garage HID's
Umnitza Angel Eyes
OEM Euro tails
Clear corners
Interior-
Seats Sparco Torino
Alcantara door panel inserts silver
Brand new OEM ///M3 floor mats
Carbon Fiber interior trim pieces
Autometer Pro-Comp Boost Gauge
Autometer Pro-Comp AFR Gauge
New silver/black ///M3 shift knob
Custom trunk floor with amps mounted in bottom
OMP Racing black suede steering wheel
Valentine One hardwire kit/windshield mount
Car Audio-
Eclipse Head Unit (w/ sub control)
Two Diamond Audio Amplifiers
Diamond Audio mids, highs in car
Two 15" Diamond Audio free air Subs in trunk
Street Wires wiring
Wheels/Tires, Brakes
Front wheels 19x8.5 BBS CH wrapped in 245/35/19 Yokahama AVS
Rear wheels 19x9.5 BBS CH wrapped in 275/30/19 Yokohama AVS
Stainless Steel brake lines
New PBR Metal Master pads in front (less than 500mi)
HP Racing 15" Rotor
HP Racing 8 Piston Caliper
Suspension components-
Front springs/coilovers (brand) H&R Coilovers (adjustable)
Bilstein front dampers
Rear springs/coilovers (brand) H&R Cupkit (adjustable)
Bilstein rear dampers
Total lowering (inches) (front) 1-3"
Front RD Adjustable Sway bar
Rear RD Adjustable Sway bar
Sparco Front strut brace (adjustable)
Energy Bushings
NuFormz Chassis reinforcements (custom)
Powerflex (brand new less than 1K miles)
Interesting pic above on the Arqray set up. Just can't wrap my head around that tho from a functionality standpoint. Instead, I'd probably run a resonator up top then have a y pipe fabricated that IMMEDIATELY fed out to both sides increasing flow, thereby eliminating the need for that crazy wrap back just to show two additional tips. Backpressure should still be fine with a setup like that.
The Arqray setup just seems to cosmetic. Thoughts?
And you'll also lose about 10 ft/lbs of torque and 10 horsepower as well. You don't want to run straight pipes on a car because there is zero backpressure so you'll really be losing power. Plus, it will sound obnoxiously loud and farty.
Here is what I would do:
1) Buy an RPI exhaust for the 530i and purchase an extra set of tips from them. Install the RPI exhaust and on the right side install the tips with a dummy backplate or short pipe leading back a bit and tack weld it in place (or with a hanger, whatever). Only problem with that is in cold weather it will be obvious that you're only getting exhaust from one side. Then you still use 1 muffler and lose no power, just gain power!
2) Another option is removing the resonator and installing the RPI exhaust there. Then run a Y pipe to the back with 4 tips of your choice (or buy another set from RPI).
