I currently have 20" wheels on my car not sure what offset, I have added 12mm spacers to the rear (no rub before the spacers) but Im getting a little rubbing over large bumps and with a passenger only on bumps and dips though, not while im driving on a smooth steady road. To get a better idea the rub is not that bad but I dont want it hear it at all. I jacked the car up to see where the tire is hitting and i can see about 1/4 of an inch on the inner rear fender well. I can see exactly wear the tire is starting to take the paint off the inner well cant be seen from outside though. The inner fender is this in length but the metal seems thin. I was thinking if I cut the small piece thats rubbing and file the sharp edge I will be fine. Any suggestions on the best way to go about this, I dont know anyone in my area who rolls fenders and not sure I want to try it myself im scared I'll mess up. I dont want to remove spacers because I love the way the car sits now... All help will be appreciated.
I have the same issue with mine under the same circumstances /sadface
Originally Posted by Persian_535i
(Post 1436629)
Why not have your fender rolled?
i had my fenders rolled. it's ridiculous how wide they made that inner fender lip. the M5 has like no lip. i had my fender cut on my old E90. you just might want to coat it with something to prevent rusting.
+1 roll the fender, Im running a 10mm spacer on a 20x10 wheel(285/30/20) tire and its fine now, with stock sport suspension.
It seems the going rate for fender rolling is about $40 per fender...
Curious...do they still cut the inner plastic liner when the fender is rolled? |
only way is roll fender n cut plastic liner ... thats wat i did or put thinner spacer
Originally Posted by balbs
(Post 1436640)
Originally Posted by mo858
(Post 1436641)
Originally Posted by sheldor535i
(Post 1436651)
(Post 1436641)
