Rear Camera
My Ride: Gone Waiting
I have install rear camera with the acm .
I have connect the camera positive wire to the rear backup light (white wire in the boot) the image is clear only if the engine is not running.
As soon as you started the engine the image is moving up and down.
If i stop the engine the image is stable.
Any idea.
Thanks
Any idea.
Thanks
My Ride: MY2005 E60 525i M Sports
you need a relay for this...i had the same problem once...
link :
http://forums.e60.net/index.php?showtopic=...mp;#entry432840
i currently don't have the acm module, but i have a gnet interface on my car. the concept is quite similar...
hope that helped...
link :
hope that helped...
link :
hope that helped...
link :
hope that helped...
should i tapped the white wire in the reverse light to connect to the relay?
Vishwen,
[quote\]
I do not have cigar lighter in the boot.
I can connect a normal relay to that is :
30 & 85 positive
86 negative
87 out to camera
[quote]
No it's not right.
It should be 30 to camera module.
85 to positive wire of reverse light
86 to negative
87 to battery positive terminal if you don't have cigarette/power source in the boot/trunk.
If you can use cap, it's great, but I don't know what value it should be. Maybe Bruce M. can help.
Here is recap
Use automotive relay.
http://www.the12volt.com/relays/relays.asp
Connect + and - terminal of reverse light to terminal 85 and 86 respectively.
Connect terminal 87 to cigarette lighter hot wire (green wire, I believe).
Connect terminal 30 to back-up cam triggering wire (the wire that you used to connect to reverse light).
Please let me know if you still have any question.
Regards,
Fred
Or use capasitors
[quote\]
30 & 85 positive
86 negative
87 out to camera
[quote]
No it's not right.
86 to negative
Here is recap
Regards,
Fred
Or use capasitors
Originally Posted by my530i' post='476098' date='Sep 30 2007, 11:20 AM
The battery main terminal
Originally Posted by vishwen' post='476110' date='Sep 30 2007, 11:45 AM
Can i take a 12v from battery , dealer said never connect anything on battery terminal
It uses 12V battery as a signal, so negligible current is drawn. Their concern is if a device connects directly to battery w/o a fuse, it might cause fire if current exceeds the wire conductivity limit. You can use as 2A fuse if you like.
Beemer
33
01-14-2019 05:13 AM
turbogate
04-11-2015 05:02 PM
