Question to people who replaced springs:
My Ride: 2006 Audi A8 4.2TDI
Previous rides:
2005 E61 530d, 20" Breyton reps, Eibach springs, M5 bumper/mirrors/MFSW
2000 Audi S6 Avant, 18" OZ, RS6 exhaust etc
1998 Audi A8 4,2Q, 19" RS4 wheels, Remus exhaust KW coilovers etc
1986 Audi 100CC, funky fresh steel rims w plastic covers, rubber lip on boot.....
1987 BMW 320i, 15" alloys + rubber lip on boot :)
1982 Opel Ascona 1,6DL, tinted windows and a big-ass subwoofer :P
So after lurking here for a while I decided to get lowered and went for the Eibach Pro-kit since it seemed to be the closest thing to stock ride.
While I absolutely will agree on that statement I also got a negative effect with vibrations at some speeds that I did not experience on stock
springs. I did have some VERY small vibrations but hardly noticeable most of the time and now they've gotten annoying so I'm trying to figure
out the cause.
I asked the guy who made the swap if they changed anything related to wheel alignment and he said no and that it should not be necessary.
Is that really correct? I remember that when going through the same procedure on the Audi I used to have they always made some adjustments
to the front end. But the BMW front end is different so I don't know if the same rule applies.
Could it also be that the small vibrations I used to have has been reinforced by the lowering? If so I should go and get the wheels balanced again.
Would appreciate some toughts from the forum on whether I should go for suspension adjustments or wheel balancing first. Or perhaps even something
else?
Besides this issue I'm extremely pleased with the springs. Car looks great and ride is still very comfortable even on the Swedish countryside's
infamous roads
And no contact anywhere even though I'm running 255/35/20 on 9" ET20 rims in the front.
Too late to get pics now so I'll be back later in the week to show off the final result.
Cheers!
out the cause.
else?
infamous roads
And no contact anywhere even though I'm running 255/35/20 on 9" ET20 rims in the front.Too late to get pics now so I'll be back later in the week to show off the final result.
Cheers!
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
It sounds like you didn't get a wheel alignment after lowering? It's usually recommended that after you put lowering springs on you get a alignment done. Hope that helps.
Previous rides:
Yeah I figured it would need a wheel alignment but this guy said it normally isn't needed. I guess that was bullcrap though so I'll talk to him again tomorrow.
You absolutely need an alignment done. He is a newb-ass mechanic.
My Ride: BMW E60 530dA, Nav. Pro., Leather redorange, black sappire met., HUD, Dynamic Drive, Active Steering, Sunroof, AC, Bi-Xenon/Adaptive, 245 275 19" with Falken 452's, Alpina Rims, el. Seats, autom. Mirrors, BMW Cellphone,
CD Changer, M Style, Interior wood border oliv (M5), LED tail lights...
+1 , not only recommended, rather necessary! With a lowering you change the balance completely - do it!
The vibrations CAN be a result of lowering, its not a must. Maybe after lowering your tires roll just on this mm, which wasn't used before..., it also can be possible, that the lower / harder springs "telephone" the vibs a bit more than the stock.
Also the chassis gums can suffer under the modified burden and transfuse the vibs.
First try complete alignment, then the next...
Originally Posted by NeRwEEzy' post='646020' date='Aug 13 2008, 04:25 PM
an alignment should be done after at least about 300 miles of driving after install where the springs had time to settle
My Ride: 2004 530i
35% tint all around
19' DPE GT7
Originally Posted by Howitzer' post='646027' date='Aug 13 2008, 03:32 PM
Some say 2-3 miles, and others say 300 miles? There is quite a difference, which is correct?
If you get a lowering by your dealer, your car won't be moved one meter...
The new springs will settle after time, you do not have to drive 2 - 300 km before settings will be done.
You are clever doing a complete setting, when chancing the tires, so the mileage will be better
My Ride: E60 Bimmer, Sports Package, Premium Package, Black/Black, Xenon Lights, 20
Model Year: 2005
Looks like you need a wheel balance... If your steering turns left or right while driving straight then you need a wheel alignment. If you have an aftermarket rims, you might need a hub centric. Good luck!!!
