question NCS Expert Pre LCI DRL
My Ride: 530i
Model Year: 2005
Hi,
I used my NCS one time, have to look if it still works on my old laptop. I want to turn off my DRL, basically hate the yellow light on the car.
I think from what I read, I will lose the AE doing this, correct? I also will upgrade to some LED for the AE, I know it's not going to be bright. Do I change the voltage on the settings? Do I need to change anything else for the high beams if I change those to LED's? Thank you so much,
Found the below researching:
Turn off DRL:
DRL_V_GEDIMMT = nicht_aktiv in the LMA
Turn up the Voltage on the AE:
Go into LMA and look for:
PWM_AN_SL_V_AL_1_34
wert_06 - ** Change to wert_01 **
PS: If you are running, or want to run HID H8's and don't want flicker with welcome lights, change:
WL_SL_1 to ** hart_einschalten **
Turn off DRL:
PWM_AN_SL_V_AL_1_34
itz MURDAH
04-07-2011 12:17 PM
msevestre
DIY: Do It Yourself
09-13-2010 07:41 PM
VirtualRain
05-07-2009 12:51 PM
