push buttons as paddle retrofit
Old Dec 10, 2008 | 01:55 AM
schulrog's Avatar
Here's something I recently did works like a charm too.
1. Added buttons to the back of the steering wheel
2. Modded the coil spring to get 2 extra pins that will allow for the extra connection through the steering wheel
3. Plug and Play hookup making for an easy installation
Now I have "paddleshifters" in the form of simple push buttons on the OEM steering wheel.
Attached Thumbnails push buttons as paddle retrofit-dscf0757.jpg   push buttons as paddle retrofit-dscf0749.jpg
Old Dec 10, 2008 | 01:59 AM
tonymac's Avatar
Creativity is freedom...
Tonymac
Old Dec 10, 2008 | 02:11 AM
Dr Dave's Avatar
but you must have still used a wiring harness to the connecters on your steptronic gearbox?
all it seems to me that has occured is you have just used your OEM steerting wheel, the rest is the same as retro fit paddle shift
but 10/10 for doing your own thing, well done.
those buttons are way to small for my sausage fingers.
Old Dec 10, 2008 | 02:24 AM
schulrog's Avatar
The buttons are perfectly placed and are bigger as they look on the pic If you have sausage fingers the buttons would be even better
Here's a pic of the adapter I made to tap into the wires where the shift knob is located.
Attached Thumbnails push buttons as paddle retrofit-dscf0783.jpg   push buttons as paddle retrofit-dscf0779.jpg
Old Dec 10, 2008 | 02:57 AM
Dr Dave's Avatar
youre the first to do such a mod as far as i know...well done.
its not my cup of tea, but if the buttons work for you......
Old Dec 10, 2008 | 03:40 AM
Bteljuice's Avatar
wooow.thats actually amazing.i wish i was good with wires in order to do this.I LOVE IT. 12/10 on that one.
how much did everything cost.
is there a time-lag on when u push the button and the gear to change?
Old Dec 10, 2008 | 06:43 AM
schulrog's Avatar
No time lag at all. it's like using the shifter itself.. oh did i mention that i retained my heated steering wheel option as well haven't quite figured out the exact cost of everything
Old Dec 10, 2008 | 08:10 AM
southgate's Avatar
how much to do this?????
Old Dec 10, 2008 | 10:26 AM
schulrog's Avatar
that really depends... do you want to switch your old steering wheel with one that has paddles or just retro your existing wheel with the buttons like i did? do you want to use your existing coil spring or get one that can be replaced? do you have a heated steering wheel?
Old Dec 10, 2008 | 10:35 AM
AKAlius's Avatar
Too cool! Can you do a DIY on this?
