purchasing 166's 19"
My Ride: Expected delivery on 15 Jan 2007 525I Olivian Green, Beige Interior, PP, CWP, PDC, SP, Rear shades,heated rear seats, Ipod fitted, Nav, Oem Rims 166, Xenon Lights, Wood grain package, illuminated door sills
Thanks guys,
Im about to purchase the 166's in 19" but I need to know if any mods or anything needs to be done when I put them on. Or are they a direct fit just a bolt on application. I have a 07 525I w/o sports package so I need to know what tire size to get also.
Thanks ALI
Thanks ALI
No mods required ... but the front wheel will stick out a bit farther than your stock wheel, and the rear wheel will be inset a bit from stock. That's why some have put spacers on the rear wheels (10mm, 12mm or even 15mm).
Tire sizes are 245/35 in front and 275/30 in back. But some also run 285/30 in back.
My Ride: 2006 525i, Premium,Cold,Xenon Packages
I am interested in going for 19" 128's to replace my stock 17" ones... Are there any pros/cons on upgrading to 19" 128s?? ANy idea how much a dealer would cost, to replace the existing stock ones with these new 19" ones? Thanks!
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Originally Posted by vafinest25' post='384837' date='Jan 29 2007, 06:59 AM
Thanks guys,
Thanks ALI
Thanks ALI
My Ride: 07' 550i sport; Sapphire Black/Auburn; sport package; steptronic; navigation with R.T.T.I.; heads up; cold weather package; Logic-7; BMW MOST ipod kit; Motorola V3 snap-in adapter; rear heated seats and rear shades; anthracite headliner; sirrius sat. radio; M-aero kit; OEM style 166 Wheels with 245/35-19 front and 285/30-19 rear Michelin PS2s.
Originally Posted by vafinest25' post='384837' date='Jan 29 2007, 09:59 AM
Thanks guys,
Thanks ALI
Thanks ALI
I purchased my 166 rims from bmwwheels.com for my 550 and I was very happy with their service. One thing to consider regarding tire size: 245/35 and 275/30 tires will keep the same diameter and thus not affect speedometer accuracy. But... these are not the sizes on the M5 and they do tend to look a little...fast and furious because the sidewall is so narrow. More importanly, I have experienced significant tramlining on my car with these profile tires (which is when your car follows grooves in the road..i.e. it moves around on the highway with a mind of its own at times). Your car rides higher and on a different suspension so it may not affect your car the same way. But consider this: I believe with a standard non-sport suspension you have the option, unlike a 545/550 sport driver, of running the M5 profile tires - 245/40 19 front and 275/35 19 rear. IMHO this setup will look a bit better and should result in less tramlining from the higher sidewall. BTW I'm running Michelin PS2s w 285/30s on the rear. Great tire but the car does not feel very planted with them on relative to my OEM 18s with snows that I have on now....
Good luck.
DRP
Good luck.
DRP
Good luck.
DRP
Originally Posted by vegastrashed' post='384891' date='Jan 29 2007, 12:15 PM
Pro: The car will look much better with 19"s. Con: Ride quality will suffer a little. You should PM quad_m for prices. Never buy from the dealer.
Yah I would be buying from him only, but probably want to get it installed at the Dealer though (since i dont have experience and dont have equipment to replace them myself).. Do I need spacers (not sure what it is though
those are good questions cool guy, yea does anyone have a spare tire with the rim on it? Or are they just the space saver spare. What about spacers what size to get. Can you guys put pics up with your comments about the rims so that I can see what your talking about. Your car year, and model also and the specs of your rims, I.E. spacers, tires,and staggered or not.
Get the wheels from quad_m and tires from Tirerack or Discount Tires. Take all the parts to a tire shop nearby for installation. There's no need to take it to the dealership. They'll rob you blind.
Spacers is a cosmetic look that will bring out the wheels. The 128s have a rear 32 offset which means that the rear wheels are inset quite a lot. Nerwezzy has the same wheels that you are interested in. I spoke to him this weekend b/c he was interested in bringing out his wheels. I recommended 15mm. This setup will not rub b/c it's only 1mm less overall then my current setup and I'm not rubbing at all. Of course, this is with 275 tires.
167s look good on all colors not just black. I've seen it in person. You'll still have the OEM donut tire for a spare. I'm not certain if a full-size tire will fit in the spare well.
