PT-CAN to LM2
My Ride: BMW E60, F01 750i, E61 530xd
Hey,
I'm retrofitting pre-lci adaptive xenon headlights and have already done the LM2 retrofit. Since I needed PT-CAN high and low to the light module pins 71 and 72 I tried tapping into the red/blue and red wires located near the light module wiring. The problem is that when I connect those wires to my LM2 the left front wheel speed sensor gets interrupted by my wiring and gives me an ABS error. Has anyone done the retrofit from pre-lci halogen to pre-lci adaptive xenon, and where have you obtained the PT-CAN from to the light module?
EDIT:
When my wires are connected the left front wheel speed sensor shows speed as 0 and other sensors work perfectly and after removing the connection it works normally.
EDIT:
Hey,
EDIT:
EDIT:
xardas
70
May 25, 2025 02:02 PM
fgin
34
Mar 16, 2020 08:46 AM
