Hi,
I have installed the new tvonnav (called E60 XBOX). It seems that everything is working fine: I can swtich from screen etc. but the problem is that I dont see anything on the screen. I have 2 rear screens and there everything is working fine. I have tried another device that can switch easily between PAL/NTSC--> no view. what do I do wrong ? |
Originally Posted by de_smet_h' date='Jul 11 2005, 08:51 AM
Hi,
I have installed the new tvonnav (called E60 XBOX). It seems that everything is working fine: I can swtich from screen etc. but the problem is that I dont see anything on the screen. I have 2 rear screens and there everything is working fine. I have tried another device that can switch easily between PAL/NTSC--> no view. what do I do wrong ? [snapback]147746[/snapback] I've installed that also. Do you see the input names in red letters on the screens top right corner (navigation, DVD , REAR ...) when you press the mute button on the remote. If you see that then the cables are atleast OK. You should see atleast something with PAL signal also, picture is just distorted. |
Do you have pictures how the installation should be done ?
I see the navigation working correctly and when the mute is pressed in chaged (after 4 times it goes back to navigation) but I dont see any red things |
Hi
Check the cables and wiring. It sounds like the in and out cable are swapped. It is highly unlikely that the unit is defective. The units are checked before being shipped. If it is defective there is NO Problem changing it but the problem is usually installer error. Feel free to call me at 718-763-7367 or email me at sales@tvandnav2go.com I will be glad to help you. Thanks Dominic of www.TVandNav2Go.com :)
I see the navigation working correctly and when the mute is pressed in chaged (after 4 times it goes back to navigation) but I dont see any red things [snapback]147875[/snapback] |
To All:
The instruction sheet refers to the white dot or marking and that you have to align it upwards etc... Basically - the PIN that the white dot corresponds to is PIN 5. On both cables. Suggest you verify that you have plugged them in correctly. All the Best Hobi On another note, Dominic... did you get my message about the screen being "lower" - ie. vertical adjustment needed? |
Hi
How did you make out??? Thanks Dominic of www.TvandNav2Go.com
Hi
I guess you figured out what was wrong because I haven't heard anything??? Thanks Dominic of www.TVandNav2Go.com
hi
i have same kind of problem but i still not get solution |
Originally Posted by intraaction' date='Jul 16 2005, 01:27 PM
hi
i have same kind of problem but i still not get solution [snapback]149689[/snapback] |
