PLEASE HELP.. WANT KIND OF RESISTORS DO I NEED
My Ride: 2006 550 SMG
I want to put these in led fogs in. Anyone know want kind of resistors I need...Thanks
http://cgi.ebay.co.uk/2pcs-HB4-9006-Fog-1W-High-Power-LED-Xenon-White-Bulb_W0QQitemZ200162566430QQihZ010QQcategoryZ72235QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You can use any resistors around 6R but make sure they have heatsinks on them. The bulbs are 51W so you can the higher you can go with the resistor the better because it will generate less heat, but if you go too high you will get an iDrive error at one point. I have some if you want send me a PM.
Originally Posted by katheikia' post='484235' date='Oct 21 2007, 09:46 PM
Anyone know who has knowledge on this, on these boards?
Hey Bruce,
These resistors won't work will they?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...A:IT&ih=018
If not, anyone have a link of what will? or can I go to radio shack and get a pair?
MK
MK
Those should do it. Just be careful where you install these. They get bl**dy hot. Why don't you install the LED lights first and they see if you get an error and only then proceed to wire these resistors up. Some lights need them others dont.
1W....the light output is not even close to being stock. i played with the 3W, 5W and 7W LEDs. the brightness is very dim compared to a regular filiament bulb. the fog light bulb is like something along the line of 50 watts or higher! i don think the light beam will be wide, even if they put a wide coliminator lense on it. like bruce say, the 6 ohm-50 watt rated is low resistance which allows high current--generating a lot of heat. if you go that route, best to like lay the resistor flat onto some safe metal surface. this helps dissipate the heat. how hot can it get? enought to melt certain plastic!
Well I just ordered the bulbs they were only around $20.00 with the shipping. I will let you guys know the results...
My Ride: 2005 530i upgraded to 2007 550i 12/20/06
Took delivery of 2008 M5 3/25/08 cf delete K&N filters, the rest stock.
what might work the best without giving a fault message in the i-drive. Once you have what you want, you could
wire in constant ohm resistors in the system, mindful of the previous heat issue.
Good luck!
The solution above is excellent but if you are going down this route make sure your potentiometer is 50W rated atleast otherwise you may fry the pot itself.
umnitza
09-02-2015 11:28 AM
