Pix of Rear License Plate Bulbs
#31
I've yet to have any problems with my rear, license plate bulbs. They still work great!
#33
Originally Posted by Torquey5' post='425261' date='May 16 2007, 08:08 PM
Looks awesome C! You really need the LCI front and rears next!
D
D
#34
My Ride: 2006 525i, Premium,Cold,Xenon Packages
Just bought the LEDs
Cant wait to do this mod!
Thanks everyone. I have Silvery Gray (A08), so went with SuperWhite color.. that should be good right or Blue?
Next mod should be Side marker conversion to LEDS! Any success on this mod?
#35
As for the side marker bulbs, you don't want LED's. You just want the invisibulbs. They are clear when they're not on, but when you turn your blinkers on, they flash "amber/yellow" like stock. This way, you avoid the "egg yolk" effect when looking at the car, but once you turn on the blinkers, they flash the normal, yellow color.
I got mine from Bimmian, but they weren't cheap. I believe there are some cheaper bulbs by other compaies. Mine are the Solaris Invisibulbs. Just make sure you get the clear bulbs with the "yellow/amber" flash. They make them in a "white" flash, which you don't want. Do a search. You'll find others.
Here are the one's I got:
http://bimmian.com/product.htm?veh=&item=SOL
They are the Mirror Coat with Amber Illumination. They're the first set, when you click on the "side turn signal bulbs".
#37
Originally Posted by coolguy' post='429195' date='May 28 2007, 08:36 PM
Thanks Calton, once I recieve the LEDs I will head to Radioshack and buy it.
These are the resistors you want...
Resistors
#39
Originally Posted by bmwbonehead' post='398746' date='Mar 5 2007, 02:14 PM
I got the bulbs individually from autolumination.com. Had to remove all the housings to figure out which ones I needed. I put blue LED's in the footwells and doorsills. I think it looks cool, but the GF hates it![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
It was quite a bit more expensive this way rather than get it from Bimmian, but I heard their set is very dim. These aren't that bright either, but I like it. If I did it over, I'd probably get a cheaper LED kit from some website like Bimmian and get separate colored LED's from autolumination for specific areas. I'll take some pics when I get a chance.
And BTW, here are the pics of my pup![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
http://forums.e60.net/index.php?showtopic=37551
#40
Originally Posted by coolguy' post='431016' date='Jun 2 2007, 02:08 AM
Pics of new interior lights pls ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
