oil catch can???
http://www.buyacehardware.com/wedco-...n-8020737.html
If you want a two piece approach buy any large open 10 qt. pan with a pour spout and this unit from Walmart that is used to transport the oil once drained.
http://www.walmart.com/ip/RhinoGear-...l-Can/20440560
- I use one like this - it's low enough to slip under the car w/o jacking. It holds more than 10 qts, has plastic grids in the opening where the oil drains so the drain plug doesn't fall into the oil, and has a spout to transfer the old oil to one-gallon plastic jugs to bring to the recycle center. Bought mine at one of the auto parts stores more than 10 years ago - can't remember which one.
Vman33
03-14-2022 04:43 AM
