offset question
I am looking for some winter wheels.
I found a set of rep style 166 wheels (18x8) with an offset of ET15. If I am right, my 08 550i has style 172s (19") with the offset of 22. By my estimation, I should be able to switch to the wheels with the ET15 (and it would push the wheels out a bit, right?
Is that 7mm going to cause rub on the front wheels (back should have plenty of room)?
The set also comes with Nokian snow tires (model is one of the Hakkapeliitta types, don't know which one) 245/40 r 18.
Does anyone forsee any troubles?
Thanks
Thanks
My Ride: Bmw 530d 2004
You can go with 8x18 et15. A smaller offset will push the wheel more out, but the width of the wheel has its affect too. You can calculate the difference between two wheels with an offset calculator. One can be found on tirerack's site on their tech section.
- Antti -
- Antti -
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
OEM 172M offsets are 18mm front and 32mm rear ,so if you have 22mm then they are replicas.
BurtonSnol3order
07-03-2015 09:28 PM
