Offset for our cars (e60)
20 inchers are too much for the E60.
In my opinion 19" is max.
But use Search and see also the Parts, Accessories and Mods section.
This has been discussed many a times...
My Ride: .
Model Year: .
Originally Posted by m7ich7ael7' post='479214' date='Oct 8 2007, 11:52 AM
Will the following application fit?
20x9 front +19 offset
20x10 rear + 19 offset
If so, what's the ideal tire size?
Please advise.
Thanks in advance
Please advise.
Thanks in advance
20x8.5 et20mm fronts with 245/30/20
20x10 et25mm rears with 285/25/20
no rubbing in the rears, but the fenders were rolled in the front.
To keep the ride height the same as stock I went with the following ^^ tire sizes. Surprisingly, the 20s w/non-run-flats are actually smoother than the 18" run-flats.
-frank
Originally Posted by mrfva' post='479292' date='Oct 8 2007, 03:40 PM
Looks like those should fit. I'm running the following set-up:
-frank
-frank
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
The 20" wheels with 19 offset is fine. You may have to roll the rear fenders depending on your choice of tires.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
as vegastrashed has said, if you use the 245/35/20 front and 275/30/20 rear combination, these will fit without rolling the arches and not rub.
If you use 285/25/20 or 295/25/20 you'll be better of to roll the rear arches.
