OEM Rear license plate mounted park distance control kit
#31
#32
Thanks! Appreciate the feed back! My 535i is black sapphire so as you say, it should blend in quite well. Since I am mostly in NYC, I don't mind if the sensor gets you closer before a continuous beep as I really just need to know when I am within a few inches of the car or wall behind. I understand its not the best solution but for $300 its not a bad solution. My only other question is - can this be easily stolen?
#33
I guess it is about as easy as stealing your license plate bracket just with a cable to cut. But there are several parts which are installed inside the car which would be missing. I have a pdf with instructions to install in a 3 series. I can email if you like. I would test it and put up pictures but I through my back out.
