OEM Mtech Fitment Problem
Old Jun 2, 2010 | 07:00 PM
PM818's Avatar
My Ride: bmw 528 i
I had my OEM MTECH kit installed at eurorev. The fitment on the rear bumper and sideskirts are perfect, but the fitment on the front bumper is a little off. There is a small gap where the fender and bumper meet, also where the headlight and bumper meet. Does anyone have this same problem? Is there anything that could be done to make the fitment perfect?
Old Jun 2, 2010 | 07:21 PM
theXman's Avatar
My Ride: 2004 530i
Can you post some pictures of the problem areas?
Old Jun 3, 2010 | 07:34 AM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
Go back to Eurorev and get them to fix it.
Old Jun 3, 2010 | 07:51 AM
peter griffin's Avatar
My Ride: 2010 550i jet black, Loaded
Model Year: 2010
Engine: N62B48
OEM kit with fitment issue? Is the kit really OEM then?
Old Jun 3, 2010 | 08:10 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
By chance did you order the correct mounting hard ware? You know there are extra parts for the LCI front M tech bumpers? The standard Metch fronts need a couple extra under cover baffles and impact absorbing parts to fit correctly.
That is for the OEM one not the knock off.
http://www.realoem.com/bmw/showparts...82&hg=51&fg=95
You would need the carrier supports and the support for both the right and left
http://www.realoem.com/bmw/showparts...75&hg=51&fg=15
part #6
Old Jun 3, 2010 | 08:12 AM
Gene's Avatar
+1 with going back to ER...
Old Jun 18, 2010 | 01:08 AM
shihwei's Avatar
What most likely happened is that you had them put on the bumper without changing the high density foam underneath it. The oe bumper uses different foam than the M-tech bumper so you'll need to get those from a local dealer. If you look in here you'll see the details for part number 3 in the picture says you need to use different shock absorber for vehicles with m aerodynamic package. Hope this helps.
Old Jun 18, 2010 | 05:36 AM
Howitzer's Avatar
+1
Nihilation
Jul 10, 2022 11:32 AM
Inness13
Jun 15, 2016 12:47 PM
tnycman
Jun 17, 2015 11:35 AM
kurtb23
Mar 18, 2015 12:22 PM
blackstarr
Mar 5, 2015 04:54 PM
