Nitrogen in tires
Old Feb 25, 2009 | 08:57 AM
Howitzer's Avatar
Originally Posted by Patrick E61' post='801245' date='Feb 25 2009, 12:33 PM
I want to do this when I get new M166 wheels and tires in April.
SCREW APRIL! I put mine on yesterday! WOOOOO !!! Winter be damned!
Old Feb 25, 2009 | 09:07 AM
Patrick E61's Avatar
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
I hear you. And I am jealous.
I worked up a sweat cleaning the remaining snow, ice and slush off of my drive way yesterday - it looked great! Until it snowed last night... More coming tomorrow.
I QUIT!!!
Old Feb 25, 2009 | 11:46 AM
NobleForums's Avatar
Originally Posted by sweetnlowe60' post='801136' date='Feb 25 2009, 06:12 AM
Not sure. Some guy told me yesterday that he got his filled and he doesn't have that slight wobble from the steering while driving. Says it's smoother. ???
The only real advantage of nitrogen is it's dry. Because it lacks moisture, you don't get the kind of pressure change you get with your TYPICAL air fillup. If you fill your tires at a station that has an air compressor with a well maintained moisture separator, clear auto drain valve, etc, than it's just as good.
Furthermore, DOT tires are far less succeptable to temperature/pressure changes than DOT-R tires. Most of the real problem (which nitrogen use is one easy way of solving) comes with very high temperatures, such as track use with DOT-R tires. Ask any Ferrari owner that tracks. Lots of them have shredded their $1800+ per set Pirelli P-Zero Corsa System DOT-R tires on 1 track day thanks to temperatures causing the moisture in their tires to heat up and cause the pressure to rise up past 36 psi. With normal DOT tires and their harder rubber compounds, they can withstand higher pressures before their tread starts chunking.
Old Feb 25, 2009 | 12:03 PM
RMG007's Avatar
Additionally, nitrogen molecules are larger than typical air, so you don't need to fill your tires with air nearly as often!
Old Feb 25, 2009 | 12:22 PM
The rate of migration through rubber is slower for nitrogen, but the difference is very small. Multiple tests have shown this. Heck, even Consumer Reports did a test. In 1 full year, nitrogen showed only a 1.3 psi reduction less than normal air.
http://blogs.consumerreports.org/cars/2007...-nitrogen-.html
Old Feb 25, 2009 | 12:41 PM
theXman's Avatar
My Ride: 2004 530i
Good call Noble. I trust the test from Consumer Reports. Don't waste your money on nitrogen, save it for other mod. Unless you plan to track your 5er.
Old Feb 25, 2009 | 12:47 PM
JAY'545's Avatar
I got mine filled at the dealer. Luckily one of the mechs there is pretty kool, he change my oil as well. Did not charge me anything for nitrogen.
Old Feb 25, 2009 | 01:37 PM
Many Costcos have free nitrogen fillup as well.
Old Feb 25, 2009 | 04:38 PM
sixcard's Avatar
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
This sounds like voo-doo to me.
You normally top off the fill in your tires with a gas that is already only 22% non-nitrogen so what do you gain?
Are we supposed to purge the tires of all that nasty air that already has 78% nitrogen.
Might be an advantge on the track or on AirForce One, but I find it hard to beleive I could tell any difference.
sixcard
Old Feb 25, 2009 | 04:49 PM
theXman's Avatar
My Ride: 2004 530i
And the reason why some people feel they get better gas mileage with nitrogen is because your tires are properly inflated. But you gte the same result with regular air if you keep track of pressure all the time.
