Next mod possibly......meth injection
Old 03-09-2011 | 09:24 AM
Luxurytax's Avatar
My Ride: 08 528I Sport/Prem
Originally Posted by white535xi
why do you believe its overkill?
Because it's not permanent power. You'll keep having to refill the tank like NOS which costs $.
I'd only use meth injection if I raced my car on the regular IMO. However, you can run meth injection systems using pure water, but you don't gain any power from it. You'll only get the cooling advantage of it.
Old 03-09-2011 | 09:56 AM
white535xi's Avatar
yea but when its running, thats an extra 50hp. A quart should last about 2-3 days and its a 2 gallon tank, so should last me about 2 weeks. And you can always turn the sytem off when not in use.
Old 03-09-2011 | 11:12 AM
houbmw's Avatar
My Ride: I have a 2007 Black Sapphire BMW 530i with SMG. It has the auburn interior, has PDC, Sports Package, Premium Package, rear automatic sunshades with manual side sunshades, 35% black tint, Upgraded angeleyes from Angelibrights, and Logic 7 Sound System
i dont see a problem as long as you can turn it on and off! Good luck! Kinda wish i had that engine...my 2007 530i has very little engine mod capabilities!
Old 03-12-2011 | 04:43 PM
Hacellular's Avatar
cooler means your running safer, less knock, means more power on hot day (YOUR NOT PULLING TIMING). You can also increase a couple of psi's when running meth with no problems. The cooler you run, the fewer possibility of detonation when your over boosting or when you have a boost spoke. This is a good power mod if you want to do 20, 30 MPH pulls. You want to be careful from a dig. Your car will not handle hard launches, you can easily break your transfer case and possibly your first gear, because of your AWD hooking and not spinning your tires. However, you may break some 0 to 60 mph records before breaking lol (hopefully you dont try that). If you want to pull on a e92 M3 or e60 M5 I would add that mod for sure plus a couple of psi. if your software is set up right a/f plus boost your good. Dyno Tune would make your car insane.... SEAN IVEY IS THE MAN TO TUNE IT.... Let me know if you want to do that.
HKninja
03-08-2016 09:50 AM
Jiawei Zhao
10-21-2015 08:46 PM
subieworx
09-21-2015 01:19 PM
PMorganRacing
F10 M5 Discussion
09-09-2015 01:10 PM
spediegunz
08-30-2015 09:43 AM
Quick Reply: Next mod possibly......meth injection
