Need License Plate warning cancelator.
http://www.amazon.com/BMW-5-01-09-Li...1536885&sr=8-2
I recently got the LED license plate bulbs (url above), I installed them and they work perfectly. But the iDrive keeps telling me there malfunction with my plate lights. Does anyone know where I can get the warning cancelators. Is not a big deal it just gets a bit annoying from time to time.
try these, worked for me. got the idea from fellow forum member C.
http://www.radioshack.com/product/index.js...rentPage=search
I have a module that cancels the errors and stops the Strobing of the LEDs. Contact me if you are interested.
I'm going to try the ones from radio shack first, Ill let you klnow if they work. If not, I will for sure contact you bruce.
Thanks guys!
Thanks guys!
Originally Posted by Krozi' post='872255' date='May 8 2009, 11:16 AM
Do you have to cut the wires to install these?
Originally Posted by nigxdoof' post='872259' date='May 8 2009, 11:23 AM
No sir. Just use those two resistors and tape into the + and - section. There's another DIY somewhere. I did a step further and soldered the pieces onto the positive and negative so that it doesn't get loose.
Originally Posted by Krozi' post='872262' date='May 8 2009, 11:25 AM
You mean just wrap the metal wires on the resistor around either wire on the cable for the license plate lights?
Check this posting out. =)
Originally Posted by nigxdoof' post='872266' date='May 8 2009, 11:32 AM
