NEED HELP with m5 166 wheels!
I have a 2008 535i and wanted to buy a set of oem M5 166 wheels. My question is if they will bolt right up or is the offset from the 166's different from my stocks. If it is different will I have to run a spacer with extended lugs. Any help would be greatly appreciated. Thanks.
My Ride: '04 545i Sapphire Black/Black 6-speed Manual, Sport, AS, CWP, Navi, Premium Sound, Bluetooth, iPod Adapter.
Perfect fit my friend..and your original lugs will work too! Get them and make sure you take pics!
The problem isn't within the wheels so much. The OEM M5 tires will not fit. You will rub big time so you will need to buy new tires if anything to fit your 535i
preferably 245/35/19 up front.
My Ride: 2004 530i
Im currently running 245/40/19 Front and 285/35/19 Rear on my OEM M5 166's.
Slight rubbing on front, but not bad at all, only when I run over deep dips in the road.
Some people also prefer to run a 12mm spacer for the rear to make it flush with the fender... I just purchased a set from Nerweezy and have yet to install them (waiting patiently)
should work if you change the front tires as mentioned above....
if you ever decide to add an exhaust, make sure you get the new 535i gt race exhaust from Race Precision.
be sure to post pics when afterwards...
Originally Posted by Speed_Force_E60' post='988788' date='Aug 25 2009, 08:43 PM
Some people also prefer to run a 12mm spacer for the rear to make it flush with the fender... I just purchased a set from Nerweezy and have yet to install them (waiting patiently) ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
with the 12mm spacers though and 166 wheels, they are only meant for the rear wheels that have the M5 offset of ET28. if you get a set of 166 wheels with the M6 offset of ET17 in the rear, you will not need spacers for that flushed look with the fenders.
My535
08-03-2015 04:57 PM
