Need advice on lowering with or without new shocks
Old 06-17-2008, 08:30 PM
jdhart73's Avatar
My Ride: 2005 545i- Titanium Gray
Thumbs up
I am lowering my 545 with H&R Sports. This is a non sport car that I will be running 20's on.
I have read some that say the sport springs are very close to stock...I want to know if I need to upgrade my shocks as well or if the factory shocks and the sport springs will be a pretty good ride?
Give me your opinions and experiences please!
Thanks,
Jake
Old 06-17-2008, 09:31 PM
DrLev99's Avatar
The H&R's are NOT close to stock ride. They are pretty harsh in comparison, and you will get a bit on bounce. On 20's your car will look great with the H&R's, but don't expect a stock ride or anything near comfortable. I had them on my old 530xi, and the ride was brutal.
Some here will disagree, but from almost everything I've read H&R's are some of the most harsh ones around. Eibach's give a ride closer to stock, but don't drop it as much as the H&R's.
Old 06-17-2008, 09:52 PM
I have the eibachs on mine with no aftermarket shocks and on 20s. Ride in my opinion is comfortable and not too bouncy. eibachs give closest ride to stock. Not too sure about H&R sports since the ride is a little harsher from what Ive heard.
Old 06-17-2008, 09:55 PM
jdhart73's Avatar
I actually chose H&R Sports based on everyones opinions of them being closest to the factory sport..LOL. So if I go with Koni FSD shocks as well do you think that will even out the playing field?
Jake
Old 06-17-2008, 10:00 PM
DrLev99's Avatar
Jake
I doubt you'll be satisfied with springs only. I am telling you, the ride is going to suck with just H&R sports! If you are going to do it, do it right!
Old 06-17-2008, 10:02 PM
jdhart73's Avatar
Ive spent a small fortune in the last month on mods so doing it right isnt a problem..LOL, I just need to know if FSD are the way to go with these springs? Will that get me a bit more of a comfortable ride?
TIA
Jake
Old 06-17-2008, 10:10 PM
DrLev99's Avatar
I'm not real familiar with mixing and matching aftermarket springs and struts. From what I know about the stock struts with H&R's, the rebound rates are off and I would surmise that the same will be true with your proposed setup, however it would probably work together a bit better. Make sure you get the aftermarket bumpstops as well.
You didn't have the choice of going with a complete coilover set?
Old 06-17-2008, 10:14 PM
jdhart73's Avatar
I suppose I had the choice but was recommended this particular set up from other guys with my same vehicle on here....
Old 06-17-2008, 10:17 PM
DrLev99's Avatar
If you have the ability, I'd scrap that setup for a complete coilover deal. I don't know much about which ones are better than others, but I'd have to say they will ALL ride better than what you are proposing!
Just as an fyi, my 530xi on those H&R's rode MUCH harsher that my M5 does now, set on full SPORT EDC mode, the harshest setting.
Old 06-17-2008, 10:45 PM
alpinewhite's Avatar
My Ride: No mods
There is nothing wrong with springs. I have friends who have 20s and H&R sport springs and are very happy with their ride. Trust me, H&R is not as harsh as DrLev99 says. I had them on my non-sport before I switched to Bilstein PSS9 coilovers. The advantage of coilovers is you can adjust the stiffness and ride height to your liking.
For me, I wanted my car to sit low and handle better (my coilovers are set to very stiff), my ride is harsh but I love how my car sits.
And if you do plan to get coilovers, I suggest you get KW v2. They have a better rebound than the PSS9 but you have to fork out a little more $$$. pm r1racer for best deals on the KW v2
BTW, Jake its me John@EuroRev
Quick Reply: Need advice on lowering with or without new shocks
