My Koni Sport Yellow Shocks Review
I get a lot of PM's about my suspension setup so I figure I can make this review here and I can always point to it later!
Here are the shocks/struts I use:
http://www.koni-na.com/cat_search.cfm?mt_i...p;submit=Search
Summary:
Before buying this product, I was scared. I've read every single one of the reviews I could find on Koni (150+) and was concerned about the ride being too rough. Sure, the ride is a little rougher, but it also recovers that much quicker! I'm not going to lie; the bumps ARE louder. These struts and shocks basically make the roughness on bumps more apparent. What I love most about these shocks/struts over other performance shocks/struts, (not necessarily KONI), is that there's much less nose dive when the car slows down. Even when stopping the nose dive is minimal with the Koni shocks. This makes for a smoother ride for me and since there's less forward and backward tilt, the car seems to respond faster. I can take turns at high speeds with ease. Highway off-ramps are a joke at 70mph+. I always wondered exactly what people meant by shocks/struts making the driver more confident in the turns... now I know first-hand. This mod is by far my favorite. Getting the price I got for these was just plain lucky, (got off an E60.net member for $275 shipped). Bottom line is if you're afraid of the roughness like I was, don't worry about it. It's adjustable! I keep them on firm during the Summer and a little softer in Winter.
Strengths:
Just as expected if not better. Without a doubt, product definitely allows the car to corner faster and tighter with more control.
Weaknesses:
Rear shocks are only adjustable when removed from the car or when the entire trunk is taken apart to access the top screw. The price is a bit high if you buy it new considering coilovers aren't much more. It's comparable to other products, but may be on the steep side if you're a college student trying to modify a depreciating asset like I am. I only bought it b/c I got a great deal from a great seller. Otherwise I wouldn't fork out the cash so quickly. But after experiencing what KONI suspension can do, I think I would consider it. I use H&R sport springs as well which were purchased brand-new and are a perfect marriage to this product.
Similar Products Used:
H&R Sport springs. KONI's are my first aftermarket suspension and I've fallen in love with them. I've had over 10,000 miles of driving on them with no issues.
Summary:
Strengths:
Weaknesses:
Originally Posted by mrfva' post='884488' date='May 20 2009, 12:35 PM
Great detailed feedback.
Sometime down the road, I'd like to switch out from my OEM sport suspension ...
My Ride: 05 545i 6MT
Glad you love the Konis
How did you adjust the rear suspension to match your spring? Did you pick a decent adjustment point, install and forget it?
Or did you go tru several adjustments and finally decide on one?
If I had installed the Konis, I would have ended up w/ the same setup as yours but I opted OEM Sport Struts instead.
Next upgrade would be Bilstein Sport I think.
Usually 1 full turn from full soft is enough it all depends on installer and driver. thats the beauty of it. Mine I believe are close to firm in rears and one full turn away from firm in fronts
