Magnaflow muffler
I am thinking of doing this mod, I have a 2008 550i. I know I have a dual muffler with dual inlet, it seems a lot of fabrication is needed to fit the Magnalow with a single inlet comapred to what I have. So I have two questions:
1- Is it worth it, I really would like a little deeper note from the muffler?
2- Is there a direct fit muffler out there?
Thanks in advance.
Thanks in advance.
if your car is stock, and you dont have any other exhaust other than the stock, then it should be a simple swap. I bought my magnaflow muffler and all they did was add a straight pipe and weld the exhaust, nothing to crazy. IT definitely improves the exhaust note, much deeper and more aggressive. If you have the budget i would get RPI exhaust, which has less droning and you gain 13WHP.
myfiveserie1818
02-20-2016 07:56 PM
