M5tech on preLci help
My Ride: 2007 530xi
Here's the situation,
2007 530xi (production 8/06) pre lci that im swapping front bumper to an M5tech replica.
My friends at trinity auto sport tell me its a direct fitment ..... just remove the foam padding and im good and I can leave my oem brake air ducts.
I've read from members I can leave the foam, but shave it down. How much??
Members have also posted I'll need different air ducts for a more proper fit (part # 511 17 896 587 and 511 17 896 588)
My question... is it that the leaving the oem ducts will not supply sufficient air or or proper fitment or both?
Can someone with info help out, especially maybe someone who did the same swap.
These are 2 photos of what I have..............
My Ride: 2006 530xi w m5 tech kit, 2007 Mercedes e63 AMG, 2005 ford expedition
I'm about to install mine in a week or so. I believe if ures is a pre lci like mine. U can use ure pre insisting air ducts. But that's info ive read so far. But don't quote me on it. lol
They styro crash pad you need to leave on the car and trim or replace with a different one that goes with that bumper. If you trim it, you only need to trim maybe 1/2 " off the bottom. You will see when you put the bumper up on the car where and about how much. Its really simple to do. I believe if you don't trim, then the foam will hold the bumper down and mess with the gaps and alignments. I did not have to touch my ducts at all.
Juji that looks great No fitment issues? How about the headlamp washer covers? Any issue with those?
My Ride: 2007 530xi
I actually did have trouble with the headlight washers. It seemed as though the molding on the mtech bumper, where the spring flips open the flap to spray the fluidd was different. I don't care for the washers since they dont really clean ..... so all I did was plug the feeder hose with a fat screw, thus disabling them. The feeder hose is under the driver side headlight. Very accessible once your bumper is off. Good luck.
umnitza
11-25-2015 11:10 AM
AlexanderE60
06-05-2015 04:35 PM
umnitza
06-02-2015 08:46 AM
