m5brakes on 535i
My Ride: 535i
m5brakes on 535i
are m5 brakes direkt fit ?
i have 2008 535i with oem 166 , i have a chance to have brakes upgraded to oem m5 rotors and calipers , not sure if this is direct fit or not , any mods required?
thanks
thanks
My Ride: 545 modded the F out
AFAIK they were directly fitted onto my 545. While you're at it tho you might as well swap out those old lines for some nice SS ones. And dustless pads too if your budget permits.
My Ride: 530i
Engine: M54
They're bolt on as long as you have big enough wheels to allow for proper wheel to brake clearance. I'm pretty sure they won't fit under those 166s if you have the 18" version of them. Double check with someone who has done it, but I think you need 19" or bigger wheels.
Hi,
I have upgraded front and rear m5 brakes + anti roll bars on my 535d. Really happy about the mod and I would strongly recommend to do this.
You will some more noise from the drilled brakes, but this just adds more fun.
Regarding the wheels, 18" works fine so no problem there. I have set of 184 for winter and they fit just perfect.
And yes, they are direct fit, but I would recommend not doing it yourself as you have to bleed the brakes after and this is quite tricky.
Good luck!
Good luck!
My Ride: 2006 530xi w m5 tech kit, 2007 Mercedes e63 AMG, 2005 ford expedition
Would they work on a xi? Don't see y not but always seem to b us xi guys get left out all the fun 2006 530xi
