M5 springs on a 07 525I
As far as fitment size it probably will but the spring rate will probably all wrong.
Originally Posted by black5' post='426851' date='May 21 2007, 01:47 PM
Will M5 springs fit on my 07 525I please let me know?
What do you mean by spring rate? What are the effects?
It's got to do w/ the weight of the car, 525/530 in a way is 'lighter' than say 545/550 or even M5 mainly on the engine weight but effect the overall weight and stuff so the 'heavier' model more than likely to have higher spring rate and if you put it on the 'lighter' model it'll probably too stiff and effect the handling.
If you notice after market spring maker like H&R and/or Eibach has a diff. part nbr. for 525/530 model than 545/550 or even M5 due to mainly on their diameter/thickness and ride height differences that mostly make up the spring rate.
So should I just go aftermarket instead of going with the m5 springs?
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Yes, go with aftermarket springs. Checkout H&R. Most people here have them or as an alternative Eibach.
