m5 paddle shifters
My Ride: 2008 550 sport with all the fixins, 07 yukon with all the fixins.
Has anyone tried to put the m5 paddle shifters on the 550 sport. And if so, did it work properly. I did a search but could not find it if anyone has previously asked this question. D
My Ride: BMW e60 525IA 12/2003
Hi
Can be made very easy on all E60/61 prod. after 09-2005 , on with the steering wheel ( M5 w. pads. ) and then a coding , and your done
Regards
BenAnd
Regards
BenAnd
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
The OP has an '08 with the LCI (electronic) shifter. For LCI the shift +/- signals are sent over a single wire vs. separate wires for pre-LCI, so I'm thinking programming would be required at a minimum -- if the standard shiftbox ECU will even recognize the paddles.
I spoke to patrick the other day and he informed me that he had plug and play and also can change the way that our shifters wk. for ex. instead of pulling(upshift) and pushing (down sift) he can make left down shift only and right upshift only just like it should have been.
