Louder Exhaust Setup
Old Aug 12, 2010 | 05:16 AM
white535xi's Avatar
Hey guys, as you all may know I currently have a quad setup on my 535xi with a magnaflow muffler. The sound is great but I am kinda getting tired of it and looking for something louder. What setup would you guys recommend? I am thinking of swapping out the magnaflow muffler and replacing it with something else. Any ideas or thoughts? Thanks
Old Aug 12, 2010 | 06:15 AM
Howitzer's Avatar
Well, you can always run pipes directly from your cats to the back (muffler delete). Won't hurt emissions but it will be mean sounding. I can't think of any other muffler that will make it louder except Eisenmann Race. However, those are very expensive and a little raspy. I'd probably go for an RPi exhaust if I were you for a more defined sound and actual HP gains.
Old Aug 12, 2010 | 06:26 AM
theXman's Avatar
My Ride: 2004 530i
Agreed. That should be the most inexpensive way to get the sound.
RPI is not a quad setup, so you will have to mod the bumper or add a dummy tip.
Old Aug 12, 2010 | 06:57 AM
FRONJONI's Avatar
My Ride: 2000 540i/6: Silver
Model Year: 2000
i posted in another thread this same suggestion
i didnt run new piping, but i installed an ac schnitzer muffler with a resonator delete on my car.
the sound was good but i wanted it louder and meaner.
removed the two cats before the resonator after the main cat and voila...much louder and a lot meaner.
im very happy with the results and it was only a $100 job.
i would do that before any drastic changes.
Old Aug 12, 2010 | 07:05 AM
cleung's Avatar
B&B exhaust should give you more volume, most guys on here that had them complained they were too loud. you could also try deleting the resonator.
Old Aug 12, 2010 | 07:21 AM
DKNewYork's Avatar
Cherry Bombs.
Wonder how that will sound on a 535.
Old Aug 12, 2010 | 07:26 AM
Gene's Avatar
rpi does not make an xi n54 set-up, it's different from the rwd...and as stated above, they do not have a quad set-up for non M e60's...
I know member pauken4 had and just recently sold an rpi exhaust on his 535xi, but even RPI does not know how he got it to fit correctly as E has said he has tried and said it does not bolt on correctly...
Old Aug 12, 2010 | 07:32 AM
you can try first taking off the resonator(s) with leaving the magnaflow on first. after that if you still want more sound, Id say go with a smaller diameter muffler like cherry bombs or go with straight pipes.
Old Aug 12, 2010 | 08:48 AM
white535xi's Avatar
Thanks guys. My first step will b removing the resenator nd if that's not loud enough I will go with a smaller size muffler. I think str8 pipes will be a little to low
Old Aug 12, 2010 | 08:53 AM
white535xi's Avatar
What would make a louder producing exhaust, resonator delete or smaller muffler?
