Logic 7 Retrofit help, Who has logic 7 Setup
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi guys i have already fitted all the logic 7 speakers in the doors and rear shelf
just need to fit the centre dash one and rewire that
i have the Logic 7 amp and the wiring plug to the amp with the wires on it
i have figured out which speaker wires connect to which wire
i have also figured out which is power and ground for the amp
i know the amp require a connection of the fibre optics to send the audio to the amp
i dont have any in my boot as i have the e60 that doesnt have tcu or no amp in the boot
i will be looking to fit the amp in the glovebox for the time being till i get a way of getting a set of fibre optic wires to feed to the back of the car as i dont think i have any if im checking the right locations
what i need to confirm is if any one that has a logic 7 setup in there car
next to the fibre optic connection on the amp there is a small four pin connector are there any wires connected to this socket at all on your car
if so can you please take a pic of the colours of the wires
as i dont have anything connected to that socket unless the seller didnt take it off from the car originally
i want to know this to...
i am planning to upgrade to logic 7 and the CIC...
LETS hope someone will help as
I checked some photos pf another logic 7 setup in another car
Apart from the 20 pin connector and 2 fibre opyics there seem to be other wires
I got the diagram for the wiring for the wires
Just need to get a set of fibre optics from the front to the rear of the car
So will fit the amp in the glove box in the mean time as thats the only play i have thr fibre optics
already done and tested now its actually really easy to get the amp working and connected
im not happy with the sound so its up for sale
bestofthebest
03-28-2016 02:47 PM
bestofthebest
01-05-2016 07:47 PM
ucsbwsr
09-19-2015 10:58 AM
umnitza
09-02-2015 11:28 AM
