led interior lighting
1) What determines intensity of the brightness of LED bulbs? let sa the bolb has 9 leds does that mean its realyl bright:?
2) If i change the interior bulbs to led, would it trigger errors?
3) Is there a certain model number of different led bulbs that fit into different situations? if so, what models?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
2. Depends. If the LCM checks each and every bulb then YES you would get errors.
3. Can't help with this one.
Thanks!!
Thanks!!
Since you sent me a PM about this I'll just answer it here.
1) Go to http://www.autolumination.com/ and whatever they say is the brightest bulb in that style is usually the case. I've purchased many bulbs from them for my car now and many past cars. I've never been disappointed with them!
2) I've changed all of my interior bulbs and have had no errors at all
3) Once again go to http://www.autolumination.com/ and research that site. The key is to make sure that you don't get bulbs that are too big. They give the actual measurements of the bulb. make sure they are close to the stock size or they won't fit back into where they are supposed to go. The base may fit according to the proper type of bulb #, but the top of the bulb (the bulb itself) may not fit back in where it goes.
I just realized that I answered a bunch of questions for you in your thread that you posted over a month ago!
http://forums.e60.net/index.php?show...53589&hl=bulbs
Good luck...just do it already!
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Once again, just like I requested in the other thread. Post some pics!
Here is my LED Interior.. the best investment ever!
Also no error message or any problems.
Sorry took so long to take pics of this.. gosh I love it.
I put this LED board into the interior, really easy to take apart, just get a small flat head screwdriver to get it out.
Oh, here's a pic of my 57 LED Turn signal... I had 24 LED bulb in there before.
EXTERIOR:
LIGHTING:
PERFORMANCE:
Damn Mike, your interior is bright as hell!
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Do these interior LEDs dim the same way as the stock bulbs?
My Ride: F10 535I
Model Year: 2016
Attachment 51305
Attachment 51306
Attachment 51307
Attachment 51308
Attachment 51309
Attachment 51305
Attachment 51306
Attachment 51307
Attachment 51308
Attachment 51309
