for the LCI tail lights, i believe it will require wiring kit and light module for e60's produced from 03/2005 up to 09/2006..
has anyone ever done this? And does it flicker or cause any errors? |
has anyone ever done this? And does it flicker or cause any errors? If you dont know about Bruce's cable's, they are plug and play for the LCI tails on Non-LCI cars. He's got a cable version 6. Check the group buy. If you are thinking about not buying the cable and wanting to wire it up yourself. Check the DIY section and look for RICKY's posts about wiring it up yourself. |
Originally Posted by nigxdoof' post='1015733' date='Sep 24 2009, 10:21 AM
Dude? really? you haven't been reading any posts? or are you referring to an alternate method to Bruce Miranda's cables?
If you dont know about Bruce's cable's, they are plug and play for the LCI tails on Non-LCI cars. He's got a cable version 6. Check the group buy. If you are thinking about not buying the cable and wanting to wire it up yourself. Check the DIY section and look for RICKY's posts about wiring it up yourself. thanks man,, kinda new to this forum thing.. once im settled in, i guess ill be a pro |
Oh man, there's plenty of info for what you are asking. Give that search button a try. Its really useful. ^_^ |
thanks, how did you do your lci taillights?.. did you buy that cable and how much? |
Check the group buy section. I believe there is one for the newest cables and a good price too.
i ordered the tails and the harness from umnitza. tails were like 750 then 470 for the harness. they got it for me its not on the site. good luck!
Originally Posted by nigxdoof' post='1015959' date='Sep 24 2009, 02:18 PM
Really? wow... that's a lot for both.... =( I got mine for total around $700.. (give or take a few dollars).
Originally Posted by dmatrixs' post='1016058' date='Sep 24 2009, 04:08 PM
Where did you get yours from nigxdoof?
As for the cables. They are like $250 from bruce in the group buy. I got it for more than that at the time they came out. Version 6. =) |
