LCI headlight conversion question
Old 05-07-2009, 12:36 AM
Dav530d's Avatar
Can second hand LCM be reprogrammed?
Old 05-07-2009, 12:37 AM
Dav530d's Avatar
Or if I buy a second hand LCM from a LCI car will it be plug and play?
Old 05-08-2009, 05:05 PM
Alex.br's Avatar
My Ride: 2007 E60 M5
I don?t think that will work. There are some LM LCI versions but only one that # ends with 144 will work with pre LCI cars retrofit. This LM couldn't be find on LCI cars.
Old 05-08-2009, 05:39 PM
r9ndy's Avatar
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
The only LM that can be coded for the retrofit ends in 4944. Part No. 61 35 9 154 944. I was told from BMW dealerships that these were discontinued when I did my install. At the time of my install SonicMS were able to order this you can give them a call.
Old 05-08-2009, 06:31 PM
Alex.br's Avatar
Yes it is LM ending # 944 not 144 like I post above. Sorry I mistype!
Old 10-02-2009, 04:41 PM
vsark's Avatar
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish. Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
for what it's worth...I have an early 04' 530i (09/03 production) which got a little damaged and needs the headlights replaced.
I want to swap out the pre-LCI headlights with the LCI ones and after reading this thread I went to the dealer to find out if there can be a direct swap without changing the Light Module. The response I got was that it is a direct swap and doesnt need any retro-fit kit. It just needs re-programming, which it would have needed anyways when they even put in the pre-LCI headlights.
So either the BMW parts guys have got this wrong or this thread is not correct?
inputs?
Old 10-02-2009, 05:02 PM
BlaSTiWi's Avatar
Nope, at least the plug are different between LCI & pre-LCI among other endless things... have the parts guys dig it up for the plug pics.
If they firmly sure of what they say than have them hold accountable for any further problem and feel free to proceed.
GL!
Old 10-03-2009, 05:34 AM
RootKit's Avatar
I'm very sure the headlights are not swap-able. The plugs are different.
Been a long while; I remember under the programming tool showed up as "lights package" so i assume
in the US it may be released as one big kit (headlights+tailights+adapters etc.)
I had the retrofit done almost 2 years ago.
GL!
Old 10-04-2009, 11:30 AM
Dav530d's Avatar
i've also done this conversion but it's not easy. Mine is pre lci halogen to lci adapt xenons. The adaptive function is inactive though. I'm sure the dealers will not do this conversion.
Old 03-21-2011, 09:37 PM
zino's Avatar
My Ride: BMW E60 520I M54
Damn, i'm about to start off with this headlight retrofit for my 04 e60, and now i read that this LCM wich ends on 4944 is discontineud
Can anybody conform this, how about other people who are busy with this retrofit? any other solutions ??
Quick Reply: LCI headlight conversion question
