LCI headlight conversion question
I just got the wiring and plugs for the LCI headlight conversion, I installed the LCI headlight today and I went in to some problem, first of all , my 05 530i can't recognize the parking light, ( which I assume it's the angel light ) . when I turn the lighting switch to parking mode , the angel light suppose to stay on constantly, after I did the installation , the LCI angel light only stay on for a few sec and then it shut off and then the Idrive display the parking light is malfunction? Why it does that? I have a Adaptive headlight w/ HID
also , I really want to find out what's the resistance ( resistor ) for the Fog Lamp for upgrading 35W HID? I search, some told me it would be 50ohm 50W , I can't find Wattage that huge ? I assume I have to get it online... can someone give me a hand on this one. thank you in advance
Didn't realise someone was doing an after market LCI headlight conversion kit. If you've got the BMW kit then you need to get your LCM re-programmed from your dealer and you wont need any resistors or anything.
From where did you get your kit?
I got the conversion harness/ plug from the dealer ,, thanx for the respond, I will have it done it at BMW . thank you
Did you get the LCM too?
where can i buy the lci headlights, taillights, and the LCM?? where should i go to get it installed???
Originally Posted by NobleForums' post='697150' date='Oct 19 2008, 06:47 PM
Yeah, my vehicle was an earlier 06, so I had to buy the headlights, taillights, and LCM. For what it's worth, just taillights and LCM doesn't work either.
He has an early car:
You can get them from realoem.com, your local dealer, or from any number of junkyards. Where to get it installed depends on where you live, of course.
How much did it cost for your dealer to update your LCM? I have a 2007 Non-LCI and my rear lights are already LCI with Bruce M's conversion box....Does anyone know how much time and cost for the dealer to update the LCM?
The LCM module itself is about $500. Programming pricing depends on the dealer.
