LCI climate control retrofit
Well if you want to buy me the advanced heater and fan matrix along with all the extra pipe work and fittings then I would lol.
did you have to do anything to get it working.
Bruce the auto setting is not quite right and the vents are stuck on the window settings, so maybe there is some thng I need to do.
if all you are trying to do is fill the gaps, then what you can do is just remove the buttons from the LCI AC and stick it on the pre-LCI AC. The reason I thought things wouldnt work directly is because the CIC people had to do a hack on the advanced AC to get it to work on the pre-LCI.
Looks good, but I agree with Bruce pull off the old switches and put them on, I do like the CCC volume button over the pre-LCI one though ![](https://5series.net/forums/public/style_emoticons/default/thumbsup.gif)
when you doing the gear selector
![](https://5series.net/forums/public/style_emoticons/default/hyper.gif)
