LCI CCC in a pre LCI E60
Old 09-29-2009, 10:12 PM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi All
Has anyone tryed to mount/re-fit the LCI-CCC in a pre LCI E60/61 ???
I have already the Nav. Prof. with the CCC for this , have got a 04/07 LCI CCC of E-bay , and would now like to mount/re-fit it in my pre LCI E60 , can see the Nav code is the same for both types ( SA609 ).
Until now I have been able to get the most functions coded and working on the LCI-CCC ( Logic7,TV.AUX,mp3,DAB,Telefon,Klima,HUD etc. ) thanks to the Ediabas NCS-Expert software , but the voice-control ( SA620 ) and the functions of the 8 bottons stil mis , do the bottons function have it's owne SA code ? anyone knows ?
Any help will much apriciated
Old 09-30-2009, 12:18 AM
phaduman's Avatar
Wow - that's a lit of retrofit work- fantastic. Sorry dont have an answer to your question, but wanted to let youknow I would be very interested in this retrofit.
Old 09-30-2009, 12:29 AM
E60Sim's Avatar
I would like to retrofit the new CIC nav / idrive system
and skip the old CCC based Pro Nav I have now...
Old 09-30-2009, 05:27 AM
Arta's Avatar
My Ride: BMW 530d '04
What says SSS? Asked to replace CCC unit?
Old 09-30-2009, 05:57 AM
545felix's Avatar
My Ride: 05 545/6
Originally Posted by BenAnd' post='1020773' date='Sep 30 2009, 02:12 AM
Hi All
voice control is a separate item that has to be "unlocked" via an upload of a file. I don't know if the ediabas software can do that.
as far as the buttons, i don't have them, but i thought they were just preset buttons, so have you tried holding one down to store something to it, like you would the older radio station preset buttons?
Old 09-30-2009, 11:57 AM
BenAnd's Avatar
Hi 545felix
I know that about the voice code , and no , you can't do it throug the Ediabas , must be done with the SSS-PROGMAN at the dealership. ( I got the car specific code for my car )
No it is not pre-set botton's as we konw them from older radios, the problem is that thy worked when I first connected the CCC in the car , but after coding different options ( TV , HUD , Logic7 etc. ) the bottons stoped working.
I have found out that the function have it's owne code ( S6VAA ) , but the problem now is that the CAS modul do not accept this code in my 12/2003 E60 , so must find out if it is enough if I change the CAS-modul in order to get access to code the CIC modul.
So the "project" can show out to be more complex as I first did expect
Old 01-12-2010, 04:00 AM
BenAnd's Avatar
Hi
Have got a lots of PM's on this issue , so please take a look here : https://5series.net/forums/index.php?showtopic=91175
Old 02-12-2011, 07:01 AM
REPTILE's Avatar
hi,
i have also retrofit the LCI CCC in my VFL car, can you tell me what option i must code to get the 8 buttons to work?
Did you have luck of activating the SVS ?
ciao
Old 02-13-2011, 02:52 AM
REPTILE's Avatar
me again
i have figured out myself, for someone with the same problem...
you must code CAPPL:
VA_FB
8_keys
VA_FB_AM_TOGGLE
aktiv
VA_FB_MODE_TOGGLE
aktiv
VA_FB_ENTERTAINMENT
aktiv
VA_FB_COMMUNICATION
aktiv
VA_FB_NAVIGATION
aktiv
and now the 8 fav buttons works
Someone knows a SA for this, so the automatic coding works?
Old 03-06-2013, 10:13 AM
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi mate did you get your 8 buttons fully working if so how was it the above coding options?
Quick Reply: LCI CCC in a pre LCI E60
