Issues with LCI tail light upgrade
Old 09-15-2009, 03:04 PM
Sanj's Avatar
Originally Posted by Dav530d' post='1008530' date='Sep 15 2009, 10:13 PM
Anyone checked this?
I have exactly the same problem,the lower rod is not as bright/flickering,i've had this for a while but thought the cable's may have needed soldering/cleaning etc,very wierd as it's doing this on both side's.
Old 09-15-2009, 03:06 PM
Sanj's Avatar
Originally Posted by bruce_miranda' post='1008567' date='Sep 15 2009, 11:12 PM
I've seen this happen before. Your battery may be low. Start the car and check when the engine is running. The old V5s were power hungry and because those LEDs are wired in series the last one is suffering. I got rid of this issue for good on the V6.
Sound's like that's the problem,how much for the new v6 cable's Bruce?
Old 09-16-2009, 12:39 AM
Dav530d's Avatar
OK update. When the car is off with sidelight on, the bottom rod doesn't work on both lights. When engine is on only the one pictured doesn't work. Uh? May also have to upgrade to V6's
Old 09-16-2009, 01:23 AM
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
unplug Bruce cable and apply 3.6V to that two pin thus to check cable issue or light issue.
Old 09-16-2009, 08:11 AM
bruce_miranda's Avatar
On the V5s there is a big capacitor that charges very slowly so although the rod may seem like its not on to begin with, given some time it will light up normally. This is one more area that was completely redesigned with the V6.
There is a special price for previous customers who want the V6. Please PM me for details.
Old 10-06-2009, 03:33 AM
Dav530d's Avatar
Update on this issue. For now everything seems to be working ok. Issue has rectified itself but may upgrade to bruces V6 cables
Old 10-06-2009, 04:37 AM
As mentioned, this is a battery charge related issue and if the battery is charged up well, it charges the kit components faster.
Old 10-06-2009, 04:49 AM
Dav530d's Avatar
I did have my battery and alternator checked once you mentioned this and both are working fine. You are the expert though so I wont question ya!
socale39
09-05-2023 08:30 AM
Koqui79
05-24-2015 06:47 PM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
rodybmw
02-27-2004 11:52 PM
Quick Reply: Issues with LCI tail light upgrade
