Installing dension now, quick questions...
My Ride: 04 525i, 04 Dinan M3
Just got my Dension wired up from what I think is correct...
I have a m-ask unit, and no mp3 function yet. I wired everything back up and the dension appears to be powered correctly, I powered from the glove compartment. My iPod is charging correctly, this should be the correct power right? I don't want the power to always be on and drain the car.
My real question is after hooking everything back up my CD player still works. Is it supposed to still work after the Dension install? Will the CD player be disabled once I have the coding done with Autologic? Any help would be appreciate, I need to make sure its wired right before putting it back together. I have the newer dension I believe, so there is a Car side and a CDC side, I only have the Car side hooked up.
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
The CD continues to work as normal as the Dension is in addition to the CD player
Is the 04 525i considered a most system? The coder I was going to have it done thru was concerned it was a MOST.
Question
Hi guys with the dension installation which one im i following Installation
Type 1:
Vehicles supporting multiple CD changers
and equipped with a CD changer
OR
Installation Type 2a:
Vehicles with an existing CD changer
These vehicles allow selection of Gateway audio sources and
the original CD changer by switching the mode between CD
Type 1:
OR
chadillac2000
42
09-13-2017 11:15 AM
turbogate
04-11-2015 05:02 PM
