Installed H&R sway bars
So I guess you did the Ultra Racing bars, then the H&R sway bars.
Can you tell me how much of a difference you felt after installing the H&R sway bars and if the Ultra Racing bars already did quite a lot for you?
Also, what suspension are you currently running ?
My Ride: Mini Cooper
the H&R were from my pre lci car that why I installed it 1s
I got the UR bars 6 months after which improved 100%
they are both diffrent work load.
Sway is to hold the wheel
http://www.gosafety....te.asp?menuid=9
UR bars are for the Chassis
http://www.gosafety....e.asp?menuid=11
I have just ordered this bar which I will change my old 1.
http://www.gosafety....e.asp?menuid=10
for the suspension it is stock but if I change I will get FSD
I can confirm that a strut bar (which pingu is getting next) helps the body rigidness upfront a lot and makes the car feel more solid when going through rough patches. Would do this mod again anytime.
DetailersDomain
Detailing Forum
05-29-2015 04:52 AM
