Inpa connection problems
My Ride: 2005 bmw 545i
Model Year: 2005
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
I just recently bought a k+dcan cable along with inpa and ncsexpert to code an aux cable. When loading up inpa both the little circles are white, the battery and ignition ones. Does anyone know how to get it to connect? I have been told some of these dcan cables are not pinned properly and that that may be causing the issue but I don’t know. Any help is appreciated!
Model Year: 2005
My Ride: 530i
Engine: M54
I don't know how they're selling that cable as a K can and D can cable then.
BMWs produced on or before 2/2007 (like your 545i) need to have pins 7 and 8 bridged to work. later cars have pins 7 and 8 separated. the end of the cable should have small screws that allow you to remove the cover for the PCB. Take a look at it and see if pins 7 and 8 are bridged together or not. Where did you get this cable from?
Model Year: 2005
![](https://cimg6.ibsrv.net/gimg/5series.net-vbulletin/2000x1504/image_de572b79193993159bd17fdd8f43ff1c4bc9b097.jpg)
Model Year: 2005
My Ride: 530i
Engine: M54
I wonder if you don't have your edibas.ini file setup correctly, that'll do it too.
scroll down to post #13 in this thread. you'll need to know what com port your USB port is using
INPA Ini path ecu path and interface ?????
Model Year: 2005
yeah everything was in order i tried changing the com ports and the port the USB was in as well and it still didn’t change anything
blinker528
05-15-2012 10:12 AM
