Inner Headlamp bulb not switching on? How to do it?
My Ride: 2008 E60 520d - 1995cc-177bhp, Business audio, Adaptive Xenons, ACS Roof & Trunk Spoilers, M6 Kidney Grill, ///M Badging, Carbon Fibre Door Lock Pins, ///M Wheel hub caps,
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Hi all,
Can someone please explain me why this section of the headlamp doesnt switch on on my car? both left and right hand side, the inner lamps dont switch on, but i can see a bulb inside.
-- Is it something to do with additional package?
-- Can i hotwire it with the main beam to make it work? (i.e switch on whenever the main beams are switched on?)
![Inner Headlamp bulb not switching on? How to do it?-headlamp.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/88468d1482365387t-inner-headlamp-bulb-not-switching-how-do-headlamp.jpg)
All i know is that my car has autolevelling headlamps, but i dont think i have the "adaptive headlamps"
EDIT: Sorry i forgot to mention - its a 2008 LCI 520D
Thanks.
Thanks.
@unknown: do u mean the high beam mode? or the Dipper mode? tried all that, only the outer lamps go high and low, but not the inner ones. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Thanks.
Thanks.
My Ride: G30 M550i
Model Year: 2018
Insane Devil, what year is your car?
If I'm guessing correctly, the lights you're talking about are used for "flash to pass" only so you need to pull the turn signal stalk towards you to get them to illuminate...
have someone pull it and youll see for yourself
Rudy, Sorry i had forgotten to add the make of the vehicle, have done now. 2008 LCI 520D
About pulling back the turn lever, i am 99% sure that doesnt do the job, but coz you and 'unknown' both say that, let me just look at it again and get back tomorrow.
In the mean time, guys, please let me know if its something else that makes that work.
thanks!
thanks!
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
You are absolutely right! I have a 2008 525 and the inner bulbs are pretty much out of the picture! Apart from the rings, they dont do anything else!
The high beams are encorporated into the outer lights, whereby in the previous models ( pre LCI ) the inner bulbs were the high beams!
I need to know as well!
Also, in some cars they can be set up as daylight driving lights via iDrive.
My Ride: Bmw 530d 2004
Wow!
I could have sweared that the inner lamps are the high beams in every E60.
I have a pre-LCI car and they sure are the high beams. That sounds so ridiculous that those bulbs would be there just for flashing when passing...
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
I have the same LCI light as you are & that inner light is NOT doing anything.
The bulb you see thru it is basically the H8 bulb for the AE ring, the kind of headlight we have is non-AHL (non-Adaptive).
On an Adaptive car the inner light will have a frosted lens and in use for cornering light and it has a separate H3 bulb.
Originally Posted by Insane Devil' post='990226' date='Aug 27 2009, 08:05 AM
Hi all,
Thanks.
Thanks.
