Ignition coils 550i
Hello Gents,
Was wandering whether or not it's usefull to replace the ignition coils of the N62 engine. I heard they get less effective over time due to the heat they are exposed to. The engine is in pretty good condition, 165.000 KM. no leakages, running smooth and little oils consumption. The general perfoemance would increase a little and the costs are not too bad...ie: € 30,- per coil.
https://www.autodoc.nl/bosch/1147804...BoChs4QAvD_BwE
Anyone care to elaborate a bit on the above?
thx....
Willem
thx....
Willem
Consider how many moving parts a coil pack has... zero. There's literally nothing at all to EVER wear out. The design results in a pretty much binary operating condition - either they work just fine, or they don't work at all, though it is possible for one to fail incrementally.
It's kind of a fetish to want to swap out all the (perfectly fine, reliable) coil packs. Lots of folks pull the BMW coil packs out (even though they were going to last much longer than the rest of the car), and replace them with aftermarket coils, which all too often results in LOTS of fun trying to chase down the new misfires.
If they're working, spend your money and time doing preventative maintenance on the other million or so things that DO wear out on our E60s.
I've been trying to work through mine as well (2006 530xi Touring). All the suspension, tie rods, wheel bearings, front brakes, water pump and thermostat, Mechatronics refresh with new fluid, differentials and transfer case fluids, flex disc and center support bearing for the rear propshaft, alternator, plugs, oil separator, both DISA valves, rear hatch wiring, rusted rear brake line, valve cover gasket, oil filter housing gaskets, for a start.
One of the almost inevitable jobs you'll end up doing is refilling the hatch hydraulic reservoir. By BMW process, it's a HUGE job, requiring removing lots of interior panels, and flipping the pump unit upside down. I figured out a way to do it that should take a competent wrench-twister about 30 minutes.
Quite a bit you did on her....true that....well I did my piece and to whatever is lurking around the corner I'd say this: enjoy it while it lasts.....![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
w.
- Replaced the camshaft gaskets
- Left steering rod
- Replaced front suspension bushings
- Rear airspings
- Replaced the leds of the middle breaklight
- Cleared all the tubes of the panorama drainage system
- Epoxy glued the lenses of the taillights
- Replaced diff and tranny fluid
- Fully flushed the brakes
- Fully flushed the clutch (thank god I got the manual)
- Fully flushed the powersteering
- Removed the clutch delay valve. A must do for manual lovers
- Plugs
- Don't have the hydraulic hatch thank god
- Don't have the x-drive either
w.
wkloppen (06-15-2022)
cmyachtie
04-06-2016 04:22 PM
