How to remove foot rest?
My Ride: 2008 550i M-Sport: RPi GT Exhaust, RPi Ram-Air, GP Thunder angel eyes and fog lamps, LED license plate lamps, Full LED interior
I got the M footrest, but does anyone know how to remove the old stock footrest? It appears that there's a clip on the top of the new one, do I need to remove some trim first to get the old one off?
Thanks for any advice!
My Ride: 2008 BMW M5
My Ride: Bmw 530d 2004
The stock one is glued into its place. You have to warm it with a heat gun if you want to get it out in one piece. Or then you can rip it off like I did: Footrest Change - DIY
- Antti -
- Antti -
Thanks so much! So did you have to remove the trim above to get the clip into place?
More than likely it is plastic welded from behind so you would need to remove or pull back the carpet enough to get to in. I am sure this is the case, since the Z4 and X5's are... I think it's a pretty standard process from the carpet mfg since the foot rest arrives pre-installed on the carpet. Most of the aftermarket kits simply attach over the existing factory cover as other as mentioned. Not quite sure how well they stay fixed though,. I guess it would depend on the method and material supplied to attach it...
chadillac2000
42
09-13-2017 11:15 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
turbogate
04-11-2015 05:02 PM
