how do I know which functions does an m5 mirror has?
I was trying to move the mirror manually and it won't move. it makes me believe it has autofold therefore it won't move manually as it moves mechanically. anyone know what I need to retrofit it? been searching in the forums but found that I need a door switch or something any more info would be greatly appreciated. Thanks in advance
My Ride: 2001 320Ci Coupè
You need to retrofit autodim aswell. There's an diy on this forum somewhere.
Edit: here it is: https://5series.net/forums/topic/119...sa430-mirrors/
If you have puddle lights, you don't need to do anything with the wiring in the door, if not you can rewire your existing wires.
thank you so much awt, found the vin number of the mirrors b582889, and my car is c003846. according to realoem, I need the mirror 51168040910 but is no longer being produced. do you know if the mirror will fit? thanks
