Hood vented GTR Style
I'm entertaining the thought of a vented style hood. I've seen several with two and four vents. Can't quite seem to decide as the four vent style seems a bit busy to me. Then there was a different one that has two vents and they are more towards the rear area. Not really interested in carbon because I will paint it and that seems like a waste, other than than the weight reduction. Does anyone have any personal experience with any of these and which manufacture is recommended and which are not?
Are the vents real or just decoration, and if they're real, what happens when it rains?
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
When it rains, minimal water might get in the vents - should not be an issue though. Even larger vents shouldn't pose any problems, as long as they're not directly over electrical stuff (and even then probably not as long as you have all engine covers/module housings/etc in place.)
I had a vented hood on my GTO, functional and large vents right over the headers, and yeah I guess water would sometimes drop down onto the engine, but never an issue. May just need to clean the areas under the vents more often.
I've seen a few and the price is a pretty wide range. Now I'm concerned that some of the lower prices may be poor quality such as wavy, bad fitment etc. I also stumbled across a few vents you can install yourself but obviously you would bending the large center raised area.
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Where did you see the vents for sale do you think that budy shop will be able to bent the middle to make raised look. Cutting and Installing vents seams doable. Wandering if anyone have done that conversion to OEM to GtR style hood or whatever it is called and what would be cheaper way?
Well, the vents that i s looked at are for a M3, I'm not too excited about them though. The center portion of your hood cant be raised, this would really require a new hood. I came across a video where they are being installed on a Acura hood, but the method would be the same.
vents: IND - Gloss Black Hood Vents - E9X M3
My Ride: Modded GS4 / Modded 525i
The guys at Ranz did the custom work on this OEM hood which is on my 5
![](http://farm3.staticflickr.com/2842/9146486304_b6a1a98f32_z.jpg)
![](http://farm3.staticflickr.com/2833/9146490292_902f58ff8a_z.jpg)
![](http://farm4.staticflickr.com/3754/9144220143_dce7010333_z.jpg)
For my GS4, I bought a carbon fiber hood from VIS and the fit is really good
![](http://farm8.staticflickr.com/7119/7585590968_b9521d0da0_z.jpg)
[QUOTE=smooth0033;1514259]The guys at Ranz did the custom work on this OEM hood which is on my 5
its this hood just paint 3d or the are real vents?
